05-10-2026
03:51 PM
02:08 PM
Canon TR4500 printer. The front cartridge cover will not open all the way to access paper jam under cartridges and cartridges themselves. The output tray doesn't drop down all the way. I did remove that tray earlier but didn't help. It goes back to it's same position.
05-11-2026 09:32 AM
Thank you for your response. All I needed to do was remove all the input paper, no then the cartridge cover opened all the way.
05-10-2026 04:56 PM
To fix a bad paper jam under the front cartridge cover of the PIXMA TR4500 series, follow these steps:
Open the Paper Output Cover
Check for Jammed Paper
Move the FINE Cartridge Holder
Remove the Jammed Paper
Inspect for Remaining Paper
Close the Paper Output Cover
Reconnect and Power On the Printer
05-11-2026 09:32 AM
