07-08-2017 01:20 PM
07-08-2017 03:34 PM
02-23-2021 10:30 AM
Agreed. Same here. Printer won't do anything with the "doors" open
02-23-2021 10:08 AM
I don't know how this can possibly happen because as soon as the printer is initiated the red warning light comes on along with the error message and the cradle as well as the printer won't function whatsoever. As well, as soon as you open those doors it really doesn't like it and sends off even more alarms stating the doors are open and it will refuse to go any further. So I don't know how you are performing these steps, because MY printer won't let you!
12-17-2017 08:00 PM
12-17-2017 08:11 PM
Thanks! Yes, I tried that several times, cleaned teh print head twice... I think the print head is dead. I've been working on it for hours, power cycling etc.
12-28-2017 08:20 PM
11-11-2020 07:30 PM
None of this has worked. I tried unplugging, releasing the ink cartridges, stopping it half way through the cycle.
12-28-2017 08:22 PM
03-15-2018 08:27 AM - edited 03-15-2018 08:31 AM
llll
My experience
I have the Canon MX925…
Superb printer although a bit slow for those in harry …
Last afternoon suddenly it stopped working with a message B200.
I was in distress because I wanted to do a lot of work.
I did read a lot here and elsewhere on methods to solve the problem. Most were ridiculous …
Eventually I went a bit boldly for the attack !!!
I took out the printer head and after I cleaned it a bit with alcohol I put it under running hot water - NOT too hot.
I kept it under the tap turning it over and over till the water turned clear.
I wiped it up, waited a bit and placed it back… with the ink cartridges.
NOTHING !!! B200 AGAIN… Great disappointment…
Yet the hope dies last.
After some trials I opened the cover and started the printer with the cover open…
THEN things started moving…
Step by step the printer came to life and printed at its best… OUAOU…
If this was helpful you will know by repeating it…
NOTE: DON’T RASH to throw the printer out and never agree with some idiots who advise you that the B200 Code shows the printer is basically unreparable or too costly to repair…
03-15-2018 03:54 PM
**bleep**! My almost new MX922 is now being recycled by Goodwill Industries. I believed the Canon Help rep who said it couldn't be fixed. Thank you anyway!
03-21-2018 07:35 PM
