07-08-2017 01:20 PM
01-28-2023 12:51 AM
Printers are disposable. Limited life. Keep up with the latested mobile phone, tablet, 5G.
B200 error.
01-29-2023 10:02 AM
So are printer heads! And compared on the replacing my MX922, I've had since 2017, that is the wiser/cheaper choice! Like so many others on here, my opinions tend to lean toward the fact that the MX922 is an awesome piece of equipment. I went on to Amazon Prime and selected a new printer head knowing if it didn't work, it wouldn't be a total loss. I unwrapped the printer head, held my breath, and installed it. After plugging it back in, I waiting until it made it's start. It works again. In my opinion, it's not the cleaning of the head. It's the chip! Chips can be programed....not sure if it's time or copies....I stand with my comment, it's in the chip!
01-31-2023 05:44 PM
Suddenly i was getting the B200 error too. Then i realized why - i hadn't used the printer in months and the ink dried out. Including in the Print Head. Cleaning a lot - no joy.
Gott a new print head. No change.
Returned that one and got another. Not cheapest or most $. I went with Best Reviews. ,,, that one worked out after some extra finagling. I cleaned out the ink catchall below the print head. (Extract the print had. there is a pan under it.) I also used rubbing alcohol to clean the rear "wall" of that space, where you see the copper contacts for the printhead.
Main idea: Even a Print Head advertised as a good fit for the MX922 may not actually work with the MX922. You might have try more than one. Reading the description very closely can help weed out ones that won't work, but that still doesn't guarantee you'll get a print head that'll work.
Be Persistent.
02-28-2023 07:24 PM
My MX922 was two printer past. My time is much more valubale then screwing arond with an error code that does not have a fix by Canon.G I'm over wating my time replacing print heads klike your cost per hour to fix doesn't comepensate for the $250 plus worth your productive hours. How many hours at what rate did you spend fixing somesing that is unfixable. If a new print head was the answer why didn't Canon say it. (Print heads are obsolete?). Total waste of my time with the B200 Error. I depreciated the printer and it's been gone.
05-30-2023 06:05 PM
I don't see any phone solution free of charge. They want me to pay $20 to get phone support.
06-03-2023 01:07 PM
This is the second time I got the B200 code. The first machine I gave up on. For some reason I never saw this fix. My second machine was used bu in better shape than the other. I just tried your fix. All I had to do is turn on then machine with the ink cover open and it cleared the code and started working. Thanks for the tip...
02-05-2026 04:47 PM
did the above and now my printer will not turn on anysuggestions
02-05-2026 07:26 PM
Maybe time for a new printer. The Mx922 model is thirteen years old.
02-06-2026 12:38 AM
I wasted too much time dealing with the B200 code and it appears that CANON still hasn't provided a simple explanation. Even if a new print head would be the fix I still gagged over the price of new ink or ease of refills.
I bought a different brand of printer years ago for about the price of the print head and can refill the ink from a bottle when needed. I still have half of the original ink in the tanks. My question to the community is: Is there a proven fix to clear the B200 and still use the same printer? Try asking all the AI models and find out haw smart AI actually is. Look at it this way. Windows 10 is no longer supported.
