07-08-2017 01:20 PM
12-28-2017 08:20 PM
12-28-2017 08:22 PM
01-06-2018 01:28 PM
I tried this method and there was a ton of ink that poured out and I figured this was going to be the solution. Unfortunately, upon reassembly and multiple power cycling I still get the B200 code. Any other ideas? I'm stumped and really don't want to go down the road of another new printer/print head that cost roughly the same.
01-07-2018 05:11 PM - edited 01-07-2018 05:12 PM
01-10-2018 10:53 PM
02-07-2018 06:43 PM
Thanks so much. Your info worked perfectly. It was worth joining this forum just to thank you, even if I never use it again.
02-25-2018 01:51 PM
02-28-2018 02:44 PM
03-15-2018 08:27 AM - edited 03-15-2018 08:31 AM
llll
My experience
I have the Canon MX925…
Superb printer although a bit slow for those in harry …
Last afternoon suddenly it stopped working with a message B200.
I was in distress because I wanted to do a lot of work.
I did read a lot here and elsewhere on methods to solve the problem. Most were ridiculous …
Eventually I went a bit boldly for the attack !!!
I took out the printer head and after I cleaned it a bit with alcohol I put it under running hot water - NOT too hot.
I kept it under the tap turning it over and over till the water turned clear.
I wiped it up, waited a bit and placed it back… with the ink cartridges.
NOTHING !!! B200 AGAIN… Great disappointment…
Yet the hope dies last.
After some trials I opened the cover and started the printer with the cover open…
THEN things started moving…
Step by step the printer came to life and printed at its best… OUAOU…
If this was helpful you will know by repeating it…
NOTE: DON’T RASH to throw the printer out and never agree with some idiots who advise you that the B200 Code shows the printer is basically unreparable or too costly to repair…
03-15-2018 03:54 PM
**bleep**! My almost new MX922 is now being recycled by Goodwill Industries. I believed the Canon Help rep who said it couldn't be fixed. Thank you anyway!
