PIXMA MX922 Set the PC to start scanning
Taylortori
My PC was previously set to scan, but I'm now getting the message "set the PC to start scanning" and don't have a clue how to fix this.  I'm not savvy enough to navigate through a ton of steps.  I need something simplified.
5 REPLIES 5
SamanthaW
Moderator
Moderator
Hi!
To have a better understanding of your issue, please let everyone know the model of the printer you have as well as the operating system on your computer.
If this is a time-sensitive matter, please check out your other support options here.
Thanks!
MX922
Is your computer running Windows or MacOS?
If you would like to speak to someone live about this issue, you will need to register your Canon gear HERE to access additional support options.
Windows.  Please if you have multiple questions necessary in order to assist me, please ask all at once.
You will need to have the Canon IJ Network Scanner Selector EX program running on your computer in order to scan from the operation panel of the printer. To ensure it is running, from the WINDOWS menu on your computer, select ALL APPS, then CANON UTILITIES, then IJ NETWORK SCANNER SELECTOR EX.
Once the program is running, please attempt to scan again.  Should you continue to experience difficulty, I recommend reaching out to Canon support. The real time feedback of a live technical support call/chat would be very beneficial in this case.
You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
Friends and Family
