04-08-2024
08:37 AM
11:12 AM
My Canon MX922 printer is printing all of my photos light and “washed-out”. I specifically process in Photoshop and Lightroom and the photos/colors look great on my laptop screen. I have the print profile set for the correct Canon paper type. I understand the printer is older, but are there any cleaning options I should consider to enhance the quality and prolong the printer life? Thanks
04-08-2024 09:49 AM
Have you printed a nozzle test pattern to see how the printer is performing?
04-08-2024 12:38 PM
I did print a nozzle test and everything is aligned, but the colors are also slightly washed out. I read you might be able to remove the print head and clean it with water, but the printer still works and didn’t want to destroy it.
04-08-2024 12:44 PM
The mx922 is 13 yrs old now and stuff does eventually wear out. A printhead is subjected to high heat and constant voltage during its lifetime. If you are not using Canon Inks, this too can be a problem. I can't guarantee cleaning the printhead would improve things. You could try, as long as you are prepared that it might do more bad than good.
04-08-2024 02:25 PM
I was thinking the same the same thing. Thanks for your help
