10-12-2017
09:54 AM
11:00 AM
I have a Pixma MX922 and I am trying to scan to a USB drive. When I plug the USB flash drive into the printer, the printer says "USB drive detected". So I set up the Scan to USB flash drive function. But when I scan I receive an error message "Cannot detect a USB flash drive". Doesn't matter if I scan from the feeder or the screen.
Any suggestions?
11-25-2020 12:13 PM
All,
I too was having this issue. I plugged several different types of USB drives in and got the same results of "you've got a drive inserted, but you don't have a drive inserted."
First time I tried, i plugged the USB drive in, then started the scanning process, selected the USB storage option and then when I got the error, I inserted many different drives, all saying what you've all seen.
Here's where it gets a little wierd: In frustration, I decided to follow the typical "power off and retry" option. So I pulled the USB out, then powered down the printer. Here's the steps that follow what I did:
So what worked for me in USB drives?
Perhaps this isn't an an issue with compatibility as more an issue of following steps in a certain order. I'd be curious if anyone can replicate this as I've described.
Michael
12-04-2020 03:28 PM - edited 12-05-2020 06:51 PM
Michael --
I had great hopes for your step-by-step procedure, but I got precisely the same non-results as I reported in my previous post: eight different USB thumb drives (ranging in size from 1 to 16GB) failed to permit scanning. In each case, I made it to your step 11, at which point the printer said, "Cannot detect a USB flash drive" -- even though it had said in step 6, "A USB flash drive is connected."!
Very frustrating. I would like to be able to use whatever USB drive I have handy, but so far have had success (as I reported) only with the USB card reader.
EDIT: based on info in above posts, I purchased a 32G SanDisk Cruzer thumb drive and tried that, and sure enough, the MX922 was able to scan and store to this drive, in contrast to my bad results with my (mostly freebie) collection of other drives.
05-10-2021 06:58 PM
Absolutely nothing works now. One day, I used any USB key a had laying around. Now, absolutely nothing works at all. This is super lame.
04-07-2022 05:58 PM
SOLUTION
Your USB Drive must be in Fat32 file format. So go to your Windows, right click on the drive, choose to format (of course this will wipe your USB drive so backup first), format to FAT32 format. Now it'll be detected by the MX922.
I can't believe how incompetent Canon's support team is.
07-16-2024 01:42 PM - edited 07-16-2024 02:08 PM
I am having the same problem. For the record, I am using a SanDisk USB.
07-16-2024 01:53 PM
You'll find all of the available information regarding this issue HERE.
07-16-2024 02:03 PM - edited 07-16-2024 02:04 PM
Here is the fix that worked for me, using MacOS Sonoma 14.5. It turns out my new USB drive had to be formatted to MS-DOS (FAT).
1. Navigate to Utilities > Disk Utility
2. With USB inserted, select USB drive from left-hand list
3. Click "Erase" (at top of Disk Utility window)
4. In pop-up, name your drive and under Format: select MS-DOS (FAT)
5. Click "Erase."
07-16-2024 02:06 PM - edited 07-16-2024 02:08 PM
Thank you, but the linked page did not address the problem in question.
