08-20-2018 01:16 PM - edited 12-05-2023 06:35 AM
I have the MX922 and it is using up color ink fast even with the preferences set to grayscale printing. How do I disable use of color ink and monitoring? I'm sick and tired of having to buy color ink cartridges when I am only printing black text documents!
02-20-2021 09:40 AM
02-20-2021 09:55 AM
04-15-2021 04:24 PM
What about replacing the color cartridges with blank ink cartridges?
08-03-2021 09:39 PM
08-04-2021 09:34 AM - edited 08-04-2021 09:35 AM
It sounds like you might be able to print using only the black cartridges by specifying MONOCHROME or BLACK & WHITE instead of grayscale. I haven't tried it myself, but that sounds like it may work.
Or - someone earlier mentioned swapping all the color cartridges with black. If that does work, you won't be able to use the printer for color printing again without changing the printhead.
08-04-2021 09:18 PM
08-04-2021 11:08 PM - edited 08-11-2021 09:35 AM
I've found another method.
I'm using a Canon TS9120 on Windows, so it may be different for others.
Wtihin the 'Devices and Printers' section of the Control Panel:
That might do it. It works for us.
original post:
Do you have a choice for monochrome instead of Black & White? If not, I'm all out of ideas on that.
02-08-2022 02:34 AM
At the suggestion of another comment here I went to my printer options for the TR4500 to fix this same issue. I have printed 5 copies of the same black and white picture, absolutely no colors, and no matter what settings I put it on, it still prints grey. My current settings are set to print with black ink only, as that's an option. However, when I try to print, even after turning off "let the app change my printing preferences," a pop up error tells me, "The [Print With] setting below will be disabled if you print with the current print settings.
Print With: Black Only"
So no matter what *I* want, the printer is set up to do what *it* wants. Why have those options in there if I can't use them? Was the point just to give me the illusion that I could do what I want? As soon as I can I'm getting another printer that isn't a Canon. This is shameful. I don't want grey pictures, I want BLACK pictures.
07-05-2022 07:56 PM
This is how I print with black only on a TS5300:
1. Page Setup->Print Options->Print with: Black Only
2. Media Type: Plain Paper
It seems that selecting some other media types (e.g. photo paper) will give the warning "[Print With] setting will be disabled"
10-05-2023 06:26 PM
10/5/23 I called today. I spent so much money on color cartridges. Tried everything. Same feelings as you! The answer I got was ALWAYS SELECT COLOR. Even if your document/page doesn't have color, it will message the printer to use the small black ink cartridge. Because, BLACK IS A COLOR! Forget the grayscale. Turn that off. (If grayscale is checked, you can uncheck it by going to your printer through your computer) That will also make the printer put colors together in an attempt to make black ink just like selecting black. So, when you are copying manually select color. When printing from your computer, select color. You know the large ink cartridge is for photos. It is a different ink that will not smear on glossy paper. I'm going to start doing this today. I'm sure it will work. I don't know why I never thought of this. It's just common sense. Good luck.
