PIXMA MX490 partial functionality
yuri10
old comp died. downloaded canon pixma drivers on new comp. i can print directly from the printer. if i print something from the comp the printer physically "prints" but the result is a blank page. if i scan i get the mssg: ubs is disconnected or the printer is off. connected and on.
??? ty
12 REPLIES 12
SamanthaW
Moderator
Moderator
Hi!
To have a better understanding of your issue, please let everyone know the model of the printer you have and the operating system on your computer.
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/MyCanonAccount
Thanks!
pixma mx490 and windows 11
lost reply?
pixma mx490  ty
ps  windows 11  ty
Hi, yuri10!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
yuri10
2nd attempt
comp died. downloaded driver to new comp. i can print from the printer directly. trying to scan i get: "printer off or usb cable not connected." if i try to print from the comp the printer "prints" a blank page.
??  TY
I recommend to have this issue looked at by our support team. Canon does have a chat team that would be happy to assist you with this issue. Please click HERE and in the chat/ask a question box that appears, ask the chat bot to speak to a live person. Our chat agents are available Monday-Friday 8:00 am to 8:00 pm ET, excluding holidays.
We look forward to hearing from you
hello samantha. where did you go? still trying to fix my problem with a pixma mx490/windows 11. downloaded the driver onto my new comp. i can print directly from the printer. scan gets me the error: ubs cable not connected- it is, printer not on- it is. if i tried to print from the comp the printer would print but spit out a blank page.
dad suggested i use the micro soft driver so i switched. same issues except that if i try to print from the comp, go to the print set-up page and click print it takes me to save as. help. ty
yuri10
5th post
if i try to scan i get mssg:
printer is off- it's on
usb cable is not connected- it is
scanner driver will close
if i print from the comp it takes me to "save as"   ???
