04-04-2024
07:35 PM
08:03 AM
Hello!
So, I've been trying to log into my MX479 via browser and for the life of me, I can't seem to get into it. I've tried the following:
Username: ADMIN or canon or CANON
Password: canon or the serial number or ADMIN or password or 1234567
I'm usually pretty good at keeping track of credentials, but this one is a head scratcher. I'm OK resetting the printer to default, but figured I'd ask just to be sure.
Thanks!
04-05-2024 12:07 AM - edited 04-05-2024 12:07 AM
Greetings ,
Devices manufactured before 2020 don't require you to set a system manager ID or PIN to access the remote UI. After 2020 you're prompted to set PIN In order to access. Resetting the printer does not typically reset the system manager ID. The default is "7654321" for the username and password.
Let us know if this helps. If not, Canon support should be able to assist you.
04-05-2024 11:06 AM
Hi Rick,
Thanks for your reply. Unfortunately, that didn't seem to work. I tried multiple variations using this number to no avail.
Hope to hear from support.
Thanks again!
