05-21-2024 01:17 PM
Hi All,
I really need some help. My PIXMA MX 490 printer did not work after power outage.
I appreciate those relevant helpful tips/points in this community. Following what I learned, here are what I did:
So, what else should I do? Any suggestions or help are highly appreciated!
06-06-2024 12:55 PM - edited 06-06-2024 12:55 PM
So we can narrow down if this is a hardware or software issue, please print a nozzle check using the steps HERE.
Once the nozzle check prints, please attach a copy of it to your reply.
We look forward to hearing from you.
06-15-2024 04:42 PM
Hi Arthur,
Thank you so much for your reply and instructions. Sorry for the delayed response, because not only previous issue persisted, but also new issue with error code B204.
The service light (orange/yellowish) kept flashing all the time, no matter how many times I turned off printer (+unplugging power cord) and then back on as instructed (or shared tips). Nevertheless, the ink cartridges couldn’t move to the center. I couldn’t print nozzle check pattern.
Note: my cartridges are nearly half-full.
Thankfully, I finally found a helpful video “Canon Pixma mx492 error code b203 or b204” After following the steps advised per video, I manually moved the cartridges to the center and tested with empty Canon Cartridges (because my ink cartridges are not Canon origin), then NO flashing yellow light anymore.
So, it seems that I may need to throw away my current ink cartridges.?
