03-29-2013 11:00 AM - last edited on 08-20-2024 11:43 AM by Danny
I printed my wedding invitations on a Canon PIXMA 560, and they are absolutely beautiful. But when I I tried to print the envelopes, there is always a dark smudge of ink on the lower right-hand side of the envelope. I have done maintenance cleaning, but I have not downloaded new drivers. The envelope is a little thicker than the paper but not not by much. Please help
02-28-2015 08:49 PM
I have a Canon MG5320 and have always had the same problem. The suggestion of changing the media to "envelope" fixed it, but the printing was not as dark. What fixed it without changing the look of the printing was to turn on "prevent paper abrasion." I went to the actual printer, and from the Home screen, selected "Setup," then "Device Settings," then "Print Settings." Hope that helps! 🙂
03-31-2013 10:27 PM
Hi Liriodendron,
So that we may better asist with this issue, please let us know what version of Windows or Macintosh you are using. Also, please let us know what program you are using to print the envelope and whether the smudge appears on the printed side or the back of the envelope
04-01-2013 10:10 AM
04-01-2013 05:09 PM
Hello Liriodendron.
Please try the following adjustment to see if we can resolve your issue:
1. From the print dialog screen, expand the third dropdown menu. This can be labeled as 'Layout', 'Copies and Pages' or the name of the program you are printing from.
2. Select 'Quality and Media'.
Once there, change the media type option from Plain Paper to Envelope. This should allow the unit to compensate for the thickness of the paper before printing.
If you continue to have difficulties, please contact our support group using the "Contact Us" link below for additional assistance.
03-10-2017 12:29 PM
I chaneged the media quality to envelope. Have done the maintenance on the printer and I am still getting black smudges???
I am using a MAC Os Sierra. I am using Microsoft Word. My printer is a Canon MX 920.
Thank you,
E
02-28-2015 08:49 PM
03-22-2015 01:06 PM
That worked for me too! Thank you so much for the post!!
04-09-2017 11:29 AM
"What fixed it without changing the look of the printing was to turn on "prevent paper abrasion." "
This also worked perfectly for me on a Canon 7520. I never would have known about that Paper Abrasion setting. Many thanks. Can get my invoices out now!
12-02-2017 10:32 AM
05-21-2020 05:34 PM
The "Prevent Paper Abrasion" setting worked for me as well, on TS9020.
I've always had some problem with smudging on envelopes.
