05-26-2019
01:39 PM
12:46 PM
I'm using a wireless printer/scanner MG3600 series from my Mac running OS10.14.1
I can't figure out how to opt for only black-and-white printing when the document or image has color on it. I'm unable to find a "grayscale" option anywhere under the print menus from any application. Can you please advise how to access grayscale printing?
Thanks.
05-30-2019
03:15 AM
08:35 AM
Hi sarahsarah,
I understand you have a PIXMA MG3650 and would like to print the document or image in blackand white only. After you have the item open and ready to print. Open the print dialog box. Below Orientation, there will be a small box that will display the current applications name (e.g. preview) click on it, adjust the name to either Quality & Media or Printer Features. Black & White or Grayscale printing option should be available for you.
05-26-2019 01:50 PM
Hello, sarahsarah!
So that the Community can help you better, we will need to know exactly which model printer you're using (it's usually on the top or front of the unit), any error messages you're seeing, and the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
05-29-2019 06:01 AM
Printer: Canon PIXMA MG3650
Error message: none (simply can't find a way to opt for black and white only printing)
OS: Mac OS 10.14.1
Connection: Wifi
Thanks for any guidance. I feel stuck printing everything in color when I really don't need or want to!
05-30-2019
03:15 AM
08:35 AM
Hi sarahsarah,
11-13-2019 04:02 PM - edited 11-13-2019 04:20 PM
I have this printer installed in 2 instances on one Mac. One as Canon MG3600, another one as Canon MG3600 series 2. The second one doesn't show the color options. The first one (the main installation) does, although they refer to the same physical printer.
01-03-2025 10:42 PM
So this is not truly "solved" in the sense that you can have your printer naturally default to black only... you have to literally check this option every time. Which you think may be a non issue if you're only printing black text, but SURPRISE, even though that may be true, you'll find that you are ALSO using your costly COLOR cartridge, something these printers do to cause you to buy more color ink, even though you may have never made a color copy of ANYthing. I find that Canon is not as fast and loose as many printer manufacturers out there... ones that will literally make you buy ink if you own their printers, by "updating" software automatically, so your old ink, which is still ink, viable and usable, and IN your machine, but is no longer usable after the "update"... CANON does not do that, which is why they have my business, but I think it's also important to call out other things like this, when in the past it was an option, at some point a bean counter said, "hey! if we remove "X" then "Y" will rise +X/Y% and the stockholders will ___!" And so it becomes a non-option and you find yourself buying color ink to print black text. (Unless you figure out a way to outsmart the printer).
