PIXMA MG3620 will not accept paper
jgrimestl
My printer will not accept paper.  I have tried all of the troubleshooting process I have found.  Cleaning rollers, unplugging and plugging back in, etc.
Any suggestions?
Anonymous
Not applicable
You could try cleaning the rollers manually it may be worth a try.
https://support.usa.canon.com/kb/s/article/ART162678
I had a Brother printer, ten years old, that developed the same issue. I bought a new printer after multiple tries to repair it. Ironically the new one is an MG3620 which has performed flawlessly since I bought it.
5 REPLIES 5
Anonymous
Not applicable
What is it doing? Jamming up? Feeding paper all the way through the path?
https://youtu.be/sBs6dR3kvLU
Common Causes
  • Paper Loading Issues: Ensure the paper is loaded correctly. The print side should face down, and the paper guides must align with the edges of the paper.
  • Paper Type and Size: Check that the media type and paper size settings match the loaded paper. Using paper that is too thick or curled can also cause feeding problems.
  • Paper Capacity: Avoid overloading the paper tray. If using multiple sheets, align the edges and do not exceed the recommended load limit.
Very quick tutorial on how to load paper inside a Canon PIXMA MG3620 Printer. Amazon Links↓↓ ■ Canon Pixma MG3620: https://amzn.to/3MAXBe9 ■ Compatible Canon Ink: https://amzn.to/41skoga Alternative HP printer: ■ HP DeskJet 2755e: https://amzn.to/3o8w9KG ■ HP OfficeJet Pro 9018e: ...
Hi Derrick,
I was using it yesterday to print a few pages.  Things were working great and then it just stopped accepting paper.  It says Paper has run out.  There is paper in there.  I removed all but one sheet, same error.  I added 6 or so sheets, same error.  I found instructions to clean the rollers using the utility provided as well as manually cleaning.  Nothing seems to work.
Anonymous
Not applicable
You used the roller cleaning function in maintenance? There are posts all over the place about this problem and I don't think a "media mismatch" is the biggest cause. I did find this one forum where a user fixed the issue themselves:
https://www.reddit.com/r/printers/comments/vullew/why_wont_my_canon_mg3620_print/
yep, already tried that 😞
Anonymous
Not applicable
