01-26-2023
08:36 PM
10:20 AM
The scanner says warming up but never connects to the printer to start scanning it gives this code after timing out. Box says ScanGear The Scanner is not available while in use by another application or user Code 5,206,8
Nothing else was printing or using the software or computer tried it several time shut it off left it off for awhile and still no change updated driver nothing helps any ideas
The computer it is on is a Desktop Hp slimline tower running window 10
Processor Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz 2.90 GHz
Installed RAM 16.0 GB (15.8 GB usable)
Device ID 12004E78-F8D8-4510-8D6A-016AFDA1E642
Product ID 00325-97212-70215-AAOEM
System type 64-bit operating system, x64-based processor
Hope this helps discribe the computer the software is on
02-02-2023 10:30 AM
Hello,
This error can also be caused by when either security software or a firewall blocks the scanner driver from working correctly. Since reinstalling the driver did not resolve the issue, I recommend contacting Microsoft and have they check your computer to see if anything is blocking the scanner driver.
02-02-2023 10:37 AM
Okay thank now I know what to try and where to look thanks I do appreciate it and will mark as accept as solution thanks again
01-26-2023 08:51 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know which operating system is running on your computer (i.e. Windows or macOS and which version) Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
01-26-2023 10:52 PM
I update the original post hope that helps
02-02-2023 10:30 AM
Hello,
02-02-2023 10:37 AM
