01-30-2024
10:42 AM
10:43 AM
I just purchased the canon pixma mg2522 for office use. It prints just fine and scans just fine, however when I go to copy something it always cuts the bottom off. Seeing has how you don't even need a computer to copy, I have no earthly idea how or if I could even fix this. any suggestions?
02-19-2024
08:18 AM
10:13 AM
James_C
I can't do that as that is not really a valid solution, that is just common sense. For anyone who has this cheap printer I have found out that scanning the document with a scanner app then printing that is the best solution to go with!
01-30-2024 11:01 AM
I get this when I attempt to do a printhead alignment...
02-07-2024 04:38 PM
Based on this type of issue, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
02-09-2024 02:07 PM
I have successfully registered the product, now what?
I also I bought a 2 yr extended warranty when I purchased this printer...
02-15-2024 09:14 AM
In your account if you select product support you will see you support options. You should have the option to call our support team or contact our online chat support team.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well
02-19-2024
08:18 AM
10:13 AM
James_C
02-20-2024 11:56 AM
I see you edited my original reply, you play a mean game...
01-20-2025 03:48 PM
What was the original post? They're changing our posts now. This world is getting tough.
I managed to find a solution. This printer does not print within a specific range. It's the default setting. This option can be changed at the time of printing.
01-20-2025 03:52 PM
The original post included profanity, so a moderator moderated it.
01-20-2025 04:14 PM
this is an issue that happens when printing a scanned document. 🤦🏼♂️
