PIXMA MG2522 Chromebook Connection
wrightcynthia34
Try get my canon pixma mg 2522 to connect to my LENOVO 300e chromebook 2nd generation laptop what need to do to make it print
2 REPLIES 2
ArthurJ
To use your PIXMA MG2522 with your Chromebook, it must first be set up for use with a Windows or Mac computer using a USB cable. To print from your Chromebook, after it is setup for use with a Windows or Mac computer, it must be set up as a Classic Printer on that computer.
To do this, please follow the steps for connecting a Classic Printer from Google's web site:
https://support.google.com/chrome/answer/1069693?hl=en
If you dont have another computer, please be advised the MG2522 is not compatible directly with your Chromebook. You would need a wireless printer that would connect to your Chromebooks native print system.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
AliceBrooks
Connecting your Canon Pixma printer to your Lenovo Chromebook can be a bit of a challenge, but it's definitely doable. First, make sure your printer is turned on and connected to your Wi-Fi network. Then, on your Chromebook, go to Settings > Advanced > Printing > Printers > Add Printer. From there, you should be able to select your printer from the list of available devices and follow the on-screen instructions to complete the setup process. If you're still having trouble, you might want to check out Multitechverse. It's an online community that's dedicated to all things tech, and they offer great advice and support for printer connectivity issues. Best of luck, and happy printing!
