PIXMA MG2500 Series - How do I make a copy of a 5X7 photo on a 5X7 blank
mearsydoats
Where do I place under the cover,  the 5X7 to be copied on a 5 X 7 photo sheet.
2 REPLIES 2
Jason
Whiz
Hello mearsydoats.
The community is eager to assist! To ensure the most accurate information is provided, we’ll need to know the model of the machine you are using. We look forward to hearing back from you!
A solution to an old problem. I have an MG2500 and make copies of 5 X 7 collages on 5 X 7 blank index cards. I use a painstaking method to get the whole print onto the card without unwanted borders. I attach the four corners of the print with artist putty to the platen so it won't move, not touching any edges of the platen, with the 7" side lined up with the platen's short side. Then I make a copy with an 8.5 x 11 blank sheet. I attach a blank index card with tiny pieces of double-sided tape on its underside to that sheet, fitting it within the frame of the copy. Then I send it through. Honestly, it shouldn't be that hard, but I've tried everything else with no luck.
