02-21-2026
12:59 PM
09:27 AM
James_C
I sell items on etsy I send via USPS with a pre-printed label.
The label format is 4X6 and I do not want to print it on a thermal printer and stick it on.
I use the back feed ramp to feed in envelopes.
I got a new laptop and do not have access to the old presets.
The envelope is about 5 3/4 x 4/12. With the Canon, I feed in the envelope on the side using the back ramp.
But if I use shrink to fit, it centers it and lowers it down.
I basically want to make a default sizing/print setting in the Canon options so it prints using as much of the envelope as possible while not being far down.
Often times when I print, it is sideways, or moved too far down/left and not large enough. I have played with the settins a lot, but I do not know how to fully compensate for this. I also see there is a weird shaped border the printer cannot use. I do not know how to consider this when sizing for printing. I can't make it print as fast as it used to either. If I change the document type, it doesn't allow me to use the back ramp.
Also, I cannot figure out what dimensions it should be and if it need to be portrait or landscape.
What do I do? I am wasting dozens of envelopes trying to fix this.
02-21-2026 07:44 PM
I want to just have my defaults set, no dragging, no nothing. I am trying to simplify the process, not make it harder.
02-22-2026 12:06 AM
I hope you can find a good simple fix.
02-22-2026 01:18 PM
A knowledge person could definitely help guide me in this. I got almost all the way there by myself before I lost the settings I had.
02-22-2026 02:17 PM - edited 02-22-2026 02:17 PM
I don't use photoshop myself but I noticed it has a position and size field at the bottom of your screenshot. Can you make adjustments there to get it to print correctly?
02-22-2026 07:10 PM
Yes, which adjustments account for the border and the differential in size/proportions to be able to utilize the most amount of space?
02-22-2026 07:29 PM
This is what I found:
To adjust the position of an image in Photoshop, follow these steps:
Select the Move Tool: Click on the Move Tool in the toolbar.
Select the Layer: Click on the layer of the image you want to move in the Layers panel.
Move the Image: Click and drag the image to the desired position. Hold the Shift key while dragging to constrain the movement vertically or horizontally.
To change the size of an image or frame:
Select the Frame: Click on the frame thumbnail in the Layers panel.
Transform the Image: Press CTRL + T (or CMD + T on Mac) to activate the Free Transform tool.
Resize: Drag the corners of the bounding box to resize the image. Hold the Shift key to maintain the aspect ratio.
Confirm Changes: Press Enter (or Return) to apply the transformation.
To change the canvas size:
Go to Image Menu: Click on Image in the top menu.
Select Canvas Size: Choose Canvas Size from the dropdown.
Set New Dimensions: Enter the new width and height, then click OK.
02-22-2026 08:01 PM - edited 02-22-2026 08:02 PM
Yes, I'm well aware of how to adjust an image in photoshop manually.
I just needed to figure out how to be able to set my printer the right way so it will have seamless printing and maximise the space.
