09-17-2025 07:02 AM
Setup a new printer yesterday, all was perfectly fine. Today I discovered that my iOS devices can see the printer, but can not connect to it.
I did all possible variants of troubleshooting - restart devices and printer, check mDNS, toggle AirPrint and IPP printing on/off, nothing helped, printer is visible but "disconnected from network".
Device info:
Main Controller:Boot ROM:DCON:Language:
| 05.10 |
| 01.00 |
| 01.05 |
| 01.15 |
dns-sd output for printer:
Canon\032LBP633Cdw._ipp._tcp.local. can be reached at Canon\032LBP633Cdw.local.:631 (interface 7) txtvers=1 rp=ipp/print note= qtotal=1 priority=10 ty=Canon\ LBP633C product=\(Canon\ LBP633C\) pdl=application/octet-stream,image/urf,image/pwg-raster,image/jpeg,application/pdf adminurl=http://Canon\ LBP633Cdw.local:80/airprint.html usb_MFG=Canon usb_MDL=LBP633C Transparent=F Binary=F TBCP=F Color=T Copies=T Duplex=T PaperCustom=T Bind=F Collate=F Sort=F Staple=F Punch=0 PaperMax=legal-A4 UUID=6d4ff0ce-6b11-11d8-8020-6cf2d820d42c usb_CMD=LIPSLX,CPCA TLS=1.2 Scan=F Fax=F URF=ADOBERGB24,CP255,DM1,PQ4,RS300,SRGB24,W8-16,FN3,IS1-4,OB10-40,V1.5 kind=document,envelope,postcard print_wfds=T mopria-certified=2.1
ChatGPT claims the problem is with TLS=1.2 part, but I have TLS disabled in IPP settings.
Appreciate your help.
09-17-2025 08:00 AM
Follow up: TLS was a false flag. After network stack reset all is working fine gain.
Will check tomorrow see if it sticks.
09-17-2025 08:00 AM
09-19-2025 06:11 AM
Ok 2 days and all runs fine. Looks like it was a firmware glitch and network reset resolved it.
