03-18-2022
04:19 PM
04:28 PM
I'm having the same problem, but without a 5200 error. My PIXMA G6020 was printing just fine.
Now it acts as if it were a "black ink only" printer. The diagnostic prints from ALL maintenance routines
(head alignment, cleaning, deep cleaning, etc.) show only black ink results, as if the color print heads don't even exist!
The diagnostic print outs *** used to *** show results in black, yellow, cyan, and magenta... now only black.
When performing a color copy from the printer's scan platter, it prints in black ink only, printing the image in grayscale,
as if I had black copy button. When I print a color image from my Windows 10 laptop using Photoshop,
the printout shows only the parts of the picture where the black ink head was used. The color portions of the image are missing
from the printout completely. When I printed the same color image with the "grayscale printing" option checked
in the advanced print settings dialog, the entire image printed, but in grayscale only
(i.e. a black and white picture...as if I printed a color image to a printer that only prints in black ink).
Since the problem appeared suddenly, and similar behavior occurs from the printer itself and print jobs spooled from
a computer, it seems like this could be a firmware issue. I vaguely remember doing a firmware update
(this was week's ago), but I don't remember. Will post a reply once I get this figured out.
02-16-2023 02:59 AM
Well, ran through all the posted fixes, never got an error, and confirming since the firmware update I have a an expensive black /grayscale printer. Guess I will pop back here when I have time to chat with Tech support to see what questions they have, and what they wouldn't post here while customers try and diagnose and possibly fix their product.
12-20-2023 05:27 PM
Fixed by running Ink Flush in the Maintenance menu. I've been having the same problem as you, updated firmware, reinstalled software, tried cleaning and deep cleaning a few times, nothing. Just now, however, I did an ink flush. That solved my problem. I think the ink maybe dried out a little and blocked the nozzles beyond the ability to deep clean.
10-30-2024 06:31 PM
How did you update the firmware?
10-30-2024 06:32 PM
How did you install the latest firmware?
