01-27-2026
02:51 PM
05:31 PM
Tiffany
I have an error message involving a g3270 printer related to the encoder strip which will need repaired. Before I do that I would like to delete a document in the print queue but cannot get passed the error message screen to get back to the main menu to do that.
01-27-2026 04:44 PM
Thank you Derrick. I There are no jobs waiting in my settings on my computer. Does that also mean there are also no jobs in the actual printer memory? The printer had started to print the job before there was a huge paper jam that end up dislodging the encoder strip. I just want to make sure as it was a sensitive document.
01-27-2026 03:58 PM
Restart printer service should work if delete printer que doesn't.
Open Print Queue:
Cancel a Job:
Open Print Queue:
Cancel All Jobs:
If the print jobs are still stuck, you can restart the Print Spooler service:
Open Services:
Windows + R, type services.msc, and press Enter.Restart Print Spooler:
Open Settings:
Windows + I to open Settings.Navigate to Printers:
Open Print Queue:
01-27-2026 04:44 PM
01-27-2026 04:58 PM
If the Windows print cue is clear, there should be no job in the printers buffer.
01-27-2026 05:29 PM
Ok - Thank you. Since I have you, is there any tricks to reconnecting the encoder strip. I have it fed through the printer head but having great difficulty getting it attached at either in the limited space. Thanks again !
