PIXMA G3200 print heads not fitting
ltaylor
I’m trying to setup my new g3200 printer and the cartridges don’t fit in the slots at all. I can’t lower and lock them in to move on to the next part of the process.
6 REPLIES 6
Moderator
Moderator
Thanks for joining the conversation, ltaylor!
So that the Community can help you better, we need to know exactly which Canon printer model you're using.  Since the PIXMA G3200 doesn't use ink cartridges of any kind, it's possible the model number you gave us is different from what's on your printer.  That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
ltaylor
Hey! Thanks for your response. I used the wrong word to explain my issue. I inserted these (maybe print heads?) and cannot close and lock them in to move onto the next step. I can’t find any solutions online regarding the issue.
Based on this type of issue,I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
Hi! Thanks for your response!
we decided to return the printer and look at other options, as I had a horrible time trying to get in touch with anyone from support. Thanks!
denm59
I just purchased the same Canon G3200 printer. I have the exact same issue and I cant get the print heads to install. If I can get help to solve the problem this printer will be going back to Amazon. I have many years in IT and this is one of several Canon printers I have owned but all previous models used regular ink cartidges. Please help.
Thanks for joining the conversation, denm59!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Friends and Family
