04-01-2025 12:10 PM
Hello
Printing from a new Mac Mini M4 with MacOS Sequoia 15.3.2 to a wi-fi connected Pixma MX925, prevously only used from Windows for several years.
Some prints come out inverted: black text on white page becomes white text on black page. This already happened twice from PDF docs obtained from different sources, and that do not show a background with color. Same documents printed from Win10 do print ok as expected.
I noticed two earlier queries:
Neither thread had a final solution. Both asked for error messages, no I did not get error messages. Both files were downloaded from outside websites, one is available fror exam if needed.
I believe the issue might have to do with the printer driver installed, which I downloaded from a Canon website, and that is woking fine with other printed documents.
Thanks
04-03-2025 06:20 AM - edited 04-03-2025 06:22 AM
I don’t think Canon is supporting that printer after macOS 13 based on the fact there is no driver later than Ventura on the US support site. You could contact the Canon support site for your locality.
04-01-2025 04:32 PM
@guardavi wrote:
Hello
Thanks
Canon doesn’t show a compatible driver for that printer and macOS 15. What driver is your printer using? You can check that in System Settings->Printers & Scanners.
04-02-2025 02:32 AM
Thanks for your attention.
Driver is
Versione file: 16.70.0.0 Data di rilascio: 06 dicembre 2022
It is the latest available, reportedly for MacOS 13, on Canon Italy site.
PDF printing does work fine, on some other documents, locally generated or downloaded. Simply, to me there is not a way to tell which file will have problems before printing.
04-02-2025 06:32 AM
Can you post a “good” file and “bad” file to a sharing service like Dropbox or One Drive?
04-02-2025 06:53 AM
Thanks John, I have two files ready to share on Google Drive: good file (I only printed page 10) and bad file: I printed pages 3-7 only, all 4 were solid black with barely visible text in white.
SHould I feel comfortable in sharing the links here? I had other cases, good and bad, but can't send due to private info contained.
Thanks, Vincenzo
04-02-2025 06:58 AM
If there is no personal or other info in the documents that wouldn’t want people to see then posting is OK. It’s up to your decision.
04-02-2025 10:59 AM
Here is the good file (I only printed page 10)
https://drive.google.com/file/d/1utQktKuRcRY7jhin0jlSby2ot49qLFLs/view?usp=sharing
Here is the bad file (I printed 4-7, and got black, wet pages with barely visible white text)
https://drive.google.com/file/d/1nX_Opye23I4K2Eo9-jw5ishqrrx4TNfX/view?usp=sharing
04-02-2025 11:55 AM
I opened the file in Preview on my MacBook Air. Printed page 4 bad on my TR8620a and Pro-100. Both have Sequoia drivers. Prints were correct. Is this the only instance of problems?
04-03-2025 06:08 AM
The file "bad" was the first instance. After the second one I started looking for info with Google, and found the discussions on Canon Community. The second instance was a completely different file, a text document obtained from a completely different source.
By the way, where should I get a driver for Sequoia MacOS?
