01-28-2014 06:18 PM - edited 01-28-2014 06:20 PM
When configuring the settings for the 922 I want to scan to the Application DEVONthink and that works successfully but at the same time I get a copy in the folder specified in the settings. Default I think is document.
I can't see a way to turn of the copy that goes to the folder Documents, which I don't need.
How can I turn this off so that I'm not duplicating my scans and only getting one copy that goes to DEVONthink.
Thanks.
OS X 10.8.5
04-09-2014 07:13 PM
Hello.
Please try the following adjustment to see if we can resolve your issue:
1. Open the IJ Scan Utility from the Canon Utilities folder in Applications.
2. Click Settings.
3. Select the Auto Scan option on the left.
4. Click 'Defaults' at the bottom.
5. Repeat this with each of the tabs on the left, then click OK.
Once this has been done, try scanning from the IJ Scan Utility to see if the program still creates duplicates of your scans.
05-05-2014 07:04 PM
Thanks for your response.
Unfortunately that doesn't make any difference.
If I reset all the options to "Default".
Then go to the document settings and select the application I want to scan into I get the same result.
One scanned item in "Documents" and one copy in the application.
