12-08-2013 01:12 PM
MY MX920 gives me the message that there is no paper in the printer, but the paper is full. I have urned off the printer multiple times and each time it gives me the same problem. Any suggestions?
01-18-2017 07:28 PM
Hi antonia208.
Thanks for suggesting that we use the "Canon MX920" setting instead of "AirPrint".
Followed your instructions and it worked like a charm.
Woo hoo!
01-31-2017 09:45 PM
Dear Team,
I have a Canon MX726 and it's brand new I only bought it yesterday and decided to start printing today. I loaded all the paper and checked for paper jams. I even did paper feeding and it still says I have no paper. However this only happens when I try to print JPEG / JPG images. Other formats are alright. I've also made sure that the paper is loaded in the lower cassette which is where the error is coming from.
Thanks for the help!
02-01-2017 01:57 AM
Hi maabeltang,
To try and resolve the issue, please ensure that the paper size and type selected in the application that you are printing the JPEG images from matches the paper size and type loaded in the printer. Should you continue to experience difficulty, we ask that you please contact a Canon technical support representative at one of the methods provided here for further assistance. A representative will be happy to assist you free of charge.
02-04-2017 11:29 AM
@mbotrell wrote:MY MX920 gives me the message that there is no paper in the printer, but the paper is full. I have urned off the printer multiple times and each time it gives me the same problem. Any suggestions?
06-05-2017 03:37 PM
Same problem. Nothing is working. Next stop - the roof to pitch the printer off of it.
06-05-2017 03:48 PM
Hi christinastl!
Thanks for posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If are you in the United States and this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team. If you live outside the United States, please click here and select your country or region for your support needs.
06-06-2017 04:48 AM
Hi christinastl,
If you have tried the prior recommendations in this thread and are still experiencing difficulty, we ask that you please contact a Canon technical support representative here for further assistance. A representative will be happy to assist you free of charge.
07-30-2017 02:16 PM
07-30-2017 02:16 PM
09-26-2017 12:24 PM
So after much testing I found a fix that works for me. ![]()
Lift the right end of the printer (as you face the front of the printer) up about 45 degrees. (You can stand the printer on it's left side as well, but then the output door falls closed.)
While this looks wonky, it is working 100% of the time now.
My WAG is that the springs which hold the rollers against the paper weakened over time and tilting the printer allows the paper to be picked up easier by separating it and reducing the force needed to pick it up.
Give it a shot and see if it works for you. A rather large printer sitting at 45 degrees on a table top makes an interesting conversation piece.
