07-15-2016
02:51 PM
03:05 PM
Stephen
"printer in error state," is not discussed anywhere I could find. Does someone have a clue to
reverse this...?
[Mod note: Personal information removed for your protection. Please see FORUM GUIDELINES]
03-14-2018 09:35 AM
I pulled the power plug from the printer for 5 minutes; that did not solve the problem, even when the printer was hard-wired to my computer. Then I read it might be a wifi/port problem. I unpluged the router. With the printer hard-wired, I was able to scan and print. Then I re-powered the router, and everything reset. Printer and scanner are working through the wifi now; hard-wire is removed since I only have one USB port and need it for other operations besides running my printer.
04-24-2018 04:18 AM
Solved in my case as below: (Firewall issue).
1) All other methods tried. (e.g. Turning off router, computer, modem etc, software reinstall, rebootoong computer, hard reset, attempt to update firmware, many others).
2) Solution - Anti Virus (Norton in this case listed the "Spooler SubSystem App" as blocked. C:\Windows\System32\spoolsv.exe as a blocked program under Firewalls Setting - Program Control - allow - apply -close.
3) Complete resolved instantly. Unclear how this suddendly was listed as a blocked program.
08-23-2018 06:27 PM
I disconnect my router and reconnected like you said and my printer is now working! Thanks for the simple fix.
10-15-2018 01:34 PM
I just got the same error message, and I have unplugged my printer. I hope this works.
10-15-2018 01:49 PM
Nope. Tried this. It didn't work.
10-15-2018 02:05 PM
Call the Canon number and they helped me fix it quickly and easily by rebooting my router. Thank you, William!
10-17-2018 11:43 PM
A great fix. Messed around for days trying to fix this problem and just noticed your suggestion. So why not, and it worked.
Thanks.
04-10-2023 08:47 PM
Calling Monday 5:47 AZ time. Not during their business hours.
