MX920 printer in error state
nichfinder77
"printer in error state," is not discussed anywhere I could find.  Does someone have a clue to
reverse this...?
[Mod note: Personal information removed for your protection. Please see FORUM GUIDELINES]
Call the Canon number and they helped me fix it quickly and easily by rebooting my router.  Thank you, William!
17 REPLIES 17
Stephen
Moderator
Moderator
Hello nichfinder77!
Welcome to the Canon Forums! The Forums aren't intended for immediate assistance. If your question is of an urgent nature, please feel free to CONTACT US either by phone during business hours or email 24 hours a day!
OK, so no one knows the solution to "printer in error state." for my MX922!?
Ramona
Hi nichfinder 77,
To try and resolve the error, please turn off the printer, unplug the power cord and leave it out for at least 5 minutes, then plug it back in and turn it back on.  If the error continues, so we can better assist you, please let us know what operating system you have on your computer (version of Windows or Mac OS X), as well as if the printer is connected wirelessly or via USB cable.
For more immedate assistance, please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) and a Canon technical support representative will be happy to help.  There is no charge for this call.
Did ALL of the above and it still isn't working ~ piece of garbage, not like my former Canon. Won't be a Canon in my future if no resolution for this!!! VERY disappointed in Canon.
“MX922 Printer in error state.” SOLVED! (at least for me.)
Had this problem for a few days. Tried to solve it myself. Rebooted laptop, re installed printer drivers, turned it on and off, rebooted router, etc. No luck.
Called Canon service. Technician led me through various procedures. We isolated problem to a router port issue, not the printer or the laptop. He emailed me information to help solve the issue with the router manufacturer and/or the internet service provider.
(By the way, you CAN print a ‘test page’ straight from the printer without a computer by going through the MX922’s own menu to its ‘Set Up’ screen. It has a pix of pliers, screwdrivers, etc. Then you must click down through to “Print LAN settings”. It is buried three or four screens deep in the ‘Set Up’ sub-menu.)
After all this, I opened a Bitcoin account and had to consult a credit card account to do it. My security program, Bitdefender, interceded with its own secure pages. I ran a scan after this transaction just to see if the security software had found anything on the laptop since the last time I checked. It didn’t, but informed me I had to update it. Which I did.
Then voila! Suddenly the MX922 started printing out the official Canon test page the tech and I tried to print out earlier. I tried printing out another document. It printed too!
The updated security software had found traces of a hotel’s WiFi that I had been using earlier in the week. I’m guessing the hotel’s WiFi had changed some things around and Bitdefender must’ve set things straight again.
So, it you get a “Printer in error state” message, it might be because an unsecured Wifi connection you may have used had switched your laptop's communication ports around.
SeemaBharti
Are you facing Windows 10 printer problems like Printer in an error state or unable to print or connect?
If your Windows 10 compatible printer’s displaying “Printer in error state” there may be a problem with the printer itself.
So before doing any changes, make sure the printer is properly turned on, connected to your PC by the cable or Wi-Fi connection. Also, check it for the low paper or ink and be sure printer’s cover isn’t open and the paper isn’t jammed.
I have also faced this annoying error a month ago and thankfully making few changes in the Port Settings through Device Manager helped me in this situation. Here's how to fix Printer in Error State:
  • First of all, open Device Manager.
  • Click on View menu and then choose "Show hidden devices".
  • Expand the Ports (COM & LPT) and right click on Printer Port then select Properties.
  • Now, go to the Port Settings tab and then select “Use any interrupt assigned to the port” option.
  • And also check the “Enable legacy Plug and Play detection” box.
  • Finally, click on OK button to save the changes and then restart your PC.
These changes in Port Settings should fix Printer in Error State in Windows 10 operating system.
Article Source:
http://www.zerodollartips.com/printer-in-error-state-windows-10/
https://support.microsoft.com/en-in/help/4028004/windows-printer-in-error-state
I hope it helps.
Thanks
msbhaven68
After fiddling around with it for awhile,  I finally found the solution and as it turned out, it was a much easier fix than what I expected.  Not sure if this is the problem with everybodys issue but all I had to do was:
With the printer turned on:
Disconnect from my ISP & then reconnect to my ISP.
As soon as I did that, this error message went away and my print job printed.
Thanks - I'll try that. It certainly can't hurt.
Hope it helps.  Good luck
Holiday
