09-08-2014 03:12 PM
09-23-2015 09:21 PM
09-23-2015 09:24 PM
no one should buy a canon until they solve the problem unless it built into the machine so that yo0u hyave to purchase a new one. I called canon tech support and they could only try to sell me another printer for a 10% discount. The tech said he never heard of erro B200?
09-23-2015 09:30 PM
09-23-2015 09:32 PM
done all suggestde, even cleaned heads. nothing workes
10-11-2015 09:27 PM
10-17-2015 02:06 AM
10-17-2015 11:10 AM
Turn off printer
Disconnect from AC
Press OK button on printer 5 times
Reconnect AC
Turn on printer
If this does not work
Try several more times
If it still does not work
Try again but do not turn on printer until next morning
This has worked for me twice so far.
Also you might try removing the print head and rinsing under hot water until water runs clear before you start the above procedure.
12-10-2015 06:26 PM
Well, I followed the directions to let the inks go halfway across and then I closed the printer and got it to start working. But a minute later it completely shut down and wont turn on at all now.
12-10-2015 08:41 PM
Well, it worked for awhile, but then died for GOOD! Went on Ebay and bought a new, SEALED printhead for $50.00, now back and running like NEW! HINT, never let an ink cartridge run out of ink, when they do so, it apparently FRIES the print head's electronics!
02-11-2016 07:49 PM
