09-08-2014 03:12 PM
06-21-2020 01:02 PM
06-24-2020 06:07 PM
my mx892 has a stuck carriage, such that I can't access the print head.
any thoughts?
03-25-2025 10:08 PM
Hello...
Yesterday I was reading your solution for the clogged head. And although I had already tried several methods. I hadn't used the hot water
I tried it today. (03/25/2025) and I want to say that my head was perfect.
In my case I was able to warm it up only in water at altitude before reaching the circuit.
Every 10 - 15 minutes I changed the water because it got dirty with what kept coming out.
After 3 or 4 times then I gave him about 4 mi on the ultrasound with hot water as well.
When I tried it on the printer it was still clogged.
But I was almost convinced that by the nozel it was very clean.
So I took it out again and started cleaning over the top.
Remove the cap, Remove the screws from the rubber bulbs as well. And being careful not to contaminate another color I started cleaning
Hot water I think was a very fundamental variable in this successful outcome.
Thank you once again..
03-26-2025 02:54 PM
Very happy that it works for you!
Joanne
03-26-2025 03:54 PM
Thanks
03-26-2025 04:09 PM
I still have air in one of the pipes. The color blue. 😭
