11-12-2015 03:20 PM
I have an MX870 multifunction printer/scanner connected via USB to my iMac which is running OS 10.11.1. The front panel of the printer will not communicate with the MAC. It has worked in the past and only recently stopped working. I have reinstalled all appropriate Canon software and made sure that the "scan the images using the operation panel of the scanner" is checked in the IJ Network Scanner icon in the menu bar. Any suggestions? Thank you!
11-14-2015 02:03 PM
Hello.
Troubleshooting with our support group will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
02-17-2018 09:08 AM
My MX870 will not send to my pc. All displays are normal. When I hit scan, it scans but nothing comes up on the pc. I am running a MAc with OS X El Capitan !0.11.6 version. Problem started yesturday. Please help.
02-20-2018 12:32 PM
Hi, Vito!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
