03-02-2026 05:01 PM
imageCLASS MF453dw with updated firmware as of 3/2/26, on its front panel does not show an option to scan from its automatic document feeder ADF as 2 sided or duplex. It does scan one side. Windows 11 scan software does show a checkbox for 2 sided scanning and when enabled on the computer, the ADF does scan 2 sides. But even then, scanning using the scanner's front panel only scans one side.
03-02-2026 10:43 PM
It's the same, but if you'd like to save to USB..
Insert your pen drive, Select Scan, Select USB Memory, Scroll down and select 2 sided (on), then Start (color or B&W).
Sorry for the poor image quality.
03-02-2026 05:40 PM
Please revisit the LCD screen. Select the Send Settings menu tab. Scroll down and look for 2-Sided original. Change from off to on.
03-02-2026 06:13 PM
I do not see a Send Settings under the menu tab. There is Menu>Function Settings>Send>Scan and Send Settings but no 2-sided original parameter there.
I am actually not ‘sending’ the scan to a remote computer but generally just want to save (send?) to USB.
For Copy, there are a variety of 2-sided options on the lcd screen.
Steve
03-02-2026 10:43 PM
03-02-2026 10:55 PM
Oh wow! Now I do notice a thin narrow scroll bar on the far right edge that disappears after 3 seconds. So it may not be noticed, so you aren’t aware there are other parameters available.
Guess I need to start trying to scroll on every menu to see if other settings are available elsewhere as well.
Thanks for the reply.
Steve
03-02-2026 11:01 PM - edited 03-02-2026 11:02 PM
Careful when flicking that scroll bar with your finger. I almost always turn something on by mistake. 🤣
The entire screen is capacitive touch screen so you can touch and flick almost anywhere.
After a while you'll get used to it. 😉
