12-24-2021 04:35 AM
Hi Community, hope someone can help me:
My MX535 is printing with horizontal gaps and therefore stretching the print. Nothing of the print is missing, it looks like the paper is forwarded too far in some parts. The printer did this with the older Software and driver Version and also with the now updated one. It appeared in a temporal context with refilling the cartridges two days ago. I tried to print with Preview (see attached file), Adobe Reader, MS Word - all with gaps. I have cleaned the printhead several times, made test-prints and the test prints appear to be normal.
Thank you for your help and merry Christmas!
Printer: Canon MX535
OS: macOS Catalina 10.15.7 (19H1615)
MacBook Pro 13" early 2015
Driver & Software: mac-mx530-1_6-mcd
Print with Preview:
This is the print
The preview:
the print-preview how it should look like
12-24-2021 09:13 AM - edited 12-24-2021 09:13 AM
If you have installed new inks, the problem is with the Printhead. Either it's still partially clogged or is at the end of its life. I suspect it's just clogged.
To confirm this, print a nozzle test pattern. If it is faint or there are gaps, you'll have your answer.
Canon Knowledge Base - Printing the Nozzle Check Pattern
12-25-2021 03:47 AM
Thanks for the answer - nozzle test print is perfect - as I mentioned. That’s not the problem. When you look at the printed document you will see that nothing is missing. It’s the print itself that is pulled apart on the paper. Any ideas?
12-18-2022 05:13 PM
i have come across your post , my printer is doing the same , did you find out how to fix it , if so can you let me know please.
thanks
wayne soppitt
12-18-2022 05:41 PM
Hi Wayne!
Sorry to hear you have the same problem. I did not get it resolved. Please let me know if you find out anything to fix this.
Thanks!
12-18-2022 05:43 PM
I will , if it gets fixed.
