10-19-2021 05:01 AM
I have Canon MX340, printing from Windows 10.
I never use colour. For years my printer worked fine with an empty colour cartridge.
Recently, after changing the black ink, I got message saying Colour ink running low.
I tried the various suggestiosn in manual, such as pressing the red inverted triangle button for 10 seconds.
Eventually, I splashed out on a new colour cartridge - which I don't intend to use.
Now there are no error messages, but I don't get a preview. The normal green preview screen appears - but it's blank.
If I now print, I get a blank page.
Any advice?
Thanks.
11-04-2021 12:35 PM
Maybe a stupid reply if you've already done this, but did you try the setting to only use the Black ink? I think this might allow the printer to ignore the Color cartdrige. Hopefully the Black will begin printing again.
Another thing...what color is the text in the item you're printing? Is it a picture or document? My apologies if you're tech savvy, but I've seen some strange things in my years doing tech support. ![]()
I have the same printer and haven't experienced these issues, which is why I'm offering some help.
11-05-2021 09:43 AM - edited 11-05-2021 09:45 AM
Thanks for your kind response.
@shaydee5 wrote:...did you try the setting to only use the Black ink? I think this might allow the printer to ignore the Color cartdrige. Hopefully the Black will begin printing again.
I wasn't aware of that option.
I found it and set to Black. So, far that hasn't solved the issue..
@shaydee5 wrote:...what color is the text in the item you're printing?
I only ever use Black. The colour cartridge has been empty for years.
But as part of the troubleshooting. I bought a new (repeat new) colour cartridge and placed it in the correct slot (with a "C" )
@shaydee5 wrote:Is it a picture or document?
A simple text document.
I've decided to do all the checks shown in your screenshot.
So far, I've done "Bottom Plate Cleaning". That showed no smudges from the internal components.
I did "Nozzle Check". That was perfect - relative to the example screenshot that Canon give.
Thanks.
12-08-2021 12:42 PM
If the nozzle check printed the black grid above the color bars, that means the black ink is flowing correctly. The issue may be related to the printer driver itself. I recommend removing the driver from your computer and then perform a reinstall of the printer driver.
12-10-2021 02:19 AM
[QUOTE=ArthurJ]
[/QUOTE]
That worked fine. Thanks.
