MP620 printer does not print data from spreadsheet, pdf file or email. I only see the gridlines.
AWD2010
When I print a spreadsheet pdf file or email, only the gridlines appear. I cannot see any thing that would be printed in black ink.
Patrick
Hi AWD2010,
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order.  The order from left to right is as follows:
CLI-221BK
CLI-221M
CLI-221Y
PGI-220PGBK
CLI-221C
Next, a test of the printer should be performed.  This will tell us if the printer is working correctly.  To do this, please load letter-sized paper in the PIXMA MP620 and follow these steps:
1.  Press <HOME>.
2.  Rotate the menu to Settings and press <OK>.
3.  Press <OK> on Maintenance.
4.  Press <OK> on Nozzle Check Pattern.
5.  Press <OK> on Yes.
The Nozzle Check will print.  Please compare your printout to the example that has been attached to the bottom of this post.  If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1.  Press <HOME>.
4.  Press <OK> on Cleaning.
After a few cleanings, please print another Nozzle Check.
1 REPLY 1
Patrick
Hi AWD2010,
CLI-221BK
CLI-221M
CLI-221Y
PGI-220PGBK
CLI-221C
1.  Press <HOME>.
1.  Press <HOME>.
