MP Navigator and High Sierra
Mike12
After installing macOS 10.13.1 (High Sierra) MP Navigator EX 4.0 has ceased to work.
243 REPLIES 243
Lili2020
Me too. Updated to High Sierra OS and now "MP Navigator has quit unexpectedly" for my Canon 9000F. I uploaded the lastest Canon drivers and software for my scanner, to no avail. I bought this scanner specifically for film and slides, and now it is nothing but a paperweight. If I have to purchase a new scanner, you bet it won't be a Canon. Come on Canon, get with it!
Have the same issue with my Pixma MX870. Talked to Canon, and they are unable to update drivers to accommodate Apple's new security measures in recent OS updates.
That said, I put Apple's Image Capture in my iMac Dock, and it works faster for me that my old MP Navigator app - far fewer steps to go through.
Well, I seem to have resolved the issue but I wish Canaon could, would, should update their software.  I've been able to successfully use Preview to scan my documents over WiFi.  Open Preview.  Under File, you should see an option to select Import Image From Canon (insert model number).  I was able to successsfully scan and save.  The interface is the same as in Image Capture.
hornfischer
Canon has confirmed to me they won’t support MP Navigator to scan with Mac OS High Sierra. I guess my MX350 will still print.
Cieltee
I had the same problem than you. My scanner (Canon MP620) didn't work anymore when I set up the last version of macOS (10.13 High Sierra). So I setup the last version of MP Navigator (v2.0.8 available at https://www.canon-europe.com/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_m...) and now everything work again for me!
Use Preview or Image Capture to scan.
THANK YOU VERY MUCH Mr alvaromartinez!!!
Your post helped me.
I have a MG8150 and it is running under High Sierra now 🙂 🙂
Spoiler
All, worthwile looking at alvaromartinez's post !!
hornfischer
Does use of Preview or Image Capture support use of the Auto Document Feeder (ADF) or just single platen scans?
I've been able to use the ADF with Image Capture.
Hi Mr hornfischer, have you tried Mr alvaromartinez link ?
http://support-hk.canon-asia.com/contents/HK/EN/0200328115.html
My MG8150 scans again as before under High Sierra 🙂
