05-31-2022 08:10 AM
My cannon MG7520 printer will turn on and start to go through its normal routine, but then unexpectedly turns off. The power cord has been checked, unplugged and replugged. Same result. Looking for other solutions if there are any.
06-03-2022 06:14 PM
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
06-01-2022 11:57 PM
Good for you! Only one way to know for sure…power up that printer! Fingers crossed! 🙂
I can tell you that after making the DNS change, I’ve used the printer about a dozen different times today—PC & iPhone—without any issues.
06-02-2022 10:58 AM
Sorry to say the printer didn’t work this morning. I’ll try to reset again. This is pretty frustrating….
06-02-2022 11:04 AM
Sorry to hear that. Do you write down the DNS IP yesterday before changing it—if you were able to change it? If so, did it begin with 192.168.XXX.XXX
06-02-2022 11:09 AM
Actually I wasn’t able to do that. I have a MG7520. I just redid the set up on the lcd printer menu. I’m going to let it go today. I have some other things to do that don’t require the printer. But I’m considering getting a different printer….
thanks for the concern.
06-02-2022 11:30 AM
No problem. I have an MG7520 as well. After you disconnect from the internet, it should be this easy to change following the instructions:
06-02-2022 05:35 PM
Thank you! I’ll try again.
06-02-2022 05:57 PM
Do I need to disconnect my wifi for everything. My printer won’t stay on long enough to disconnect from there
06-02-2022 07:01 PM
If you can disconnect your internet access from your router, you can leave the WiFi on. If you have a separate modem and router, just unplug the ethernet cable from the back of the modem and your printer should power up normally. You’ll be able to make the DNS change at that point. After you make the change. Turn off the printer. Reconnect the ethernet plug and you should be back to printing without issue.
06-02-2022 06:51 PM
Thank so much!!!! The photo really helped. It’s working!!!!!
I’m still feeling a little uneasy though. I wonder if Canon will ever address this.
06-02-2022 06:54 PM
Awesome! Until they do, at least it’s working.
