07-05-2020 06:56 AM
I think I replaced one of the inks too soon, and now I am paying the price. One ink was empty, so I replaced it, and at the same time another was low so I replaced it. And the printer has decided to stop working. I am getting error 1414 ink tank not recognized.
So far I have tried the following:
Removing all inks, put them back in one at a time, and the same ink (cyan) tank is not recognized
Press stop for a number of seconds to reset screen - nothing happens
Press stop and on at the same time to reset - when screen comes on the normal screen shows up for two seconds, then the ink tank error shows again
Press stop, shut printer off, unplug for a minute, plug back in - error screen shows
I feel like nothing is working! This has been a great printer for us, we have had it for several years, which I have had several friends tell me it is unusual for a printer to even last that long. Any other tips are appreciated, thank you.
07-06-2020 01:11 PM
Hi tcb547,
Please make sure that all of the tape/cellophane has been removed from the cyan ink tank. Also, look in the slot in the printer where the cyan ink tank is placed and make sure there isn't anything blocking the contacts between the printer's slot and the ink tank. If there is a small piece of paper or foreign object in the slot, it would cause the ink tank to be not recognized.
Please make sure that you are using genuine Canon ink tanks. If you are not, please replace the cyan ink tank with a genuine Canon ink tank.
If the issue persists, there could be a fault with the printer in which your PIXMA MG6620 would require service. You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002 seven days a week, 8am to Midnight. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
07-06-2020 01:11 PM
Hi tcb547,
07-06-2020 01:17 PM
