12-31-2015 11:50 AM
I have cleaned rollers, but the paper gets stuck as it is pulled into the printer. A 1003 code tells me to load the paper. I can see the top sheet of paper start to load when I press "copy", but I can hear a click as if the leading edge is hung up. Any ideas?
01-04-2016 10:16 AM
Hello.
There may be an internal hardware issue that is causing this error and the noise that you have mentioned. Please contact our support group using the "Contact Us" link below for additional assistance with this matter.
01-05-2018 06:17 AM
canon error 1003 solution
Press the HOME button, select Setup, Device settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select Setup, Device settings, and then select cassette incorrect paper detection to No
this will solver error 1003
