11-18-2019 09:26 PM - edited 11-20-2019 03:52 PM
I've been using a PIXMA MG5520 to print and scan since April, 2014. Sometime in the past couple of weeks, it lost the ability to scan. I can still print, I just can't scan. I'm running Windows 10 Home, Version 1909, OS Build 18363.476.
When I try to use the Canon IJ Scan Utility to scan, I get the following message:
An error has occurred.
Turn the device off and then back on.
Scanner driver will be closed.
Code:2,250,200
I turned the MG5520 off and back on, and tried again.
Same error.
I did a hard reset (with the printer on, I yanked the plug then plugged it back in), and tried again.
Same error.
Using Settings... Devices... Printers & Scanners on the PC, I removed the device, then from Device Manager I uninstalled the printer and deleted the drivers. I downloaded the most recent driver package from the Canon Web site and re-installed the drivers and software. As part of the installation (from the printer), I added the printer to my WiFi network and double-checked that the settings were correct. Setup... Device settings... LAN settings... Confirm LAN settings... WLAN setting list showed Connection: Active, SSID: [the correct and only available SSID], Communication mode: Infrastructure. I tried scanning again.
Same error.
Then I tried using the printer's controls to scan. I selected Scan, PC. The Select PC screen appeared, and the only choice available was "Local (USB)". Since the printer is not connected via USB, this was also a dead end.
I have double- and triple-checked my router and my security settings (I have Webroot installed). The settings have not been changed in months, and there is no error log relating to the scanner. I also tried deactivating my security software to see what would happen, but that didn't help: Same error.
What do I have to do to get scanning working again?
Larry
P.S. It would be physically impossible to connect this printer to its PC via USB, so that is not a solution in my case. Based on the error messages I've seen, I'm guessing that the problem involves a failure to communicate via WiFi, but WiFi really is the only workable option for me.
11-21-2019 03:55 PM
I was able to print, but unable to scan via iOS.
01-25-2020 02:30 PM
Same problem, but I found a solution. Turning off & on no help, but turning off and leaving it off for a while worked. I don't know for how long. I don't use the scanner a lot so this is not a major inconvenience. I used to leave it on, but no more. Maybe a leaking vacuum tube when it gets hot? 😉
