02-05-2014 12:37 PM
My MG5320 was working fine for over a year, now it doesn't print at all. When I send a print job, the printer goes through all the motions, sounds like it's printing, and ejects the paper, but it's blank. I've put in new cartridges (a few times), run the nozzle clean and deep clean but none of that helps. Have downlaoded and installed the latest drive, removed and cleaned the print head (using distilled water) and still no printing.
I've hooked it up via usb connection to three different computers (Mac, Win 7, Win XP) and it behaves the same. It scans OK just doesn't print. There's no error code.
Any idea what is going on?
10-16-2016 10:38 PM
This is very upsetting! I have the same problem. I've Deep Cleaned the heads twice, then following instruction on the Web, took out the printing head and rinsed it in warm water, dried it and replaced it. Still nothing but blank pages. This problem it seems has been going on for years and I see no satisfactory answer except to buy a new machine. Shame on you Canon!
10-17-2016 11:15 AM
Hi Rosie
It is extremely frustrating and buried in the firmware and nothing to do with the actual jets. I was so angry I went straight out an bought an Epson.. Bad choice. After you are used to a Canon and how easy it is to use it did not work for me.. and the jets kept blocking.. you cannot take the head out to clean.. and they DO NOT like third party inks at all. So, scrapped that as well and back to Canon and hope they have sorted the problem.
01-01-2017 01:04 PM
I have exactly the same problem with my MG5320. I called their tech group & they had no answers, just that it would have to be sent in for them to look at. Since I'm not getting an error code, I assume a new print head isn't going to help with my issue. Canon - the fact that so many users are experiencing EXACTLY the same problem for years and you haven't provided any solution for it is shameful. I'm with the other users that will have to replace this unit - and it won't be with another Canon - probably go with an HP and I'll tell others to stay away from Canon given their lack of response to a pervasive problem with their printers.
03-08-2017 08:56 AM
Originally I was going to ignore this and just go buy a new printer after reading how many people are having the same problem. MG5320 printing blank pages. I decided to add myself to the thread so everyone can see how many people are having the issue with no resolution from Cannon except send it in to be repaired. There has to be a better solution. Much cheaper to buy another printer, and like many of you I will be buying another brand this time.
It was time because the printer carteidges are among the most expensive out there.
Blav1300
04-01-2017 07:17 PM
04-05-2017 09:18 PM
ugh... same thing happened to me with my MG7120... abs nothing prints even after multiple cleaning and alignment runs
nothing prints when i just use the devise as a copier, either.
looks like it also affected several other Canon models, and all around the same time.. seems like some firmware that is used in all these MG models may have gone bad
06-23-2017 10:13 AM
06-23-2017 01:41 PM
Careful what you buy... I went for an Epson and regretted it so much I scrapped it within a month and bought new Canon... fingers crossed they have sorted the problem for the current models.
This problem is a pig and Canon should have released a firmware update to sort it but don't throw out the baby with the bathwater, Canon printers are generally great and much easier to use than the opposition AND they tolerate third party inks without any problem.... plus, if they do clog up, you can remove the print head and clean it... try that with an Epson!
08-09-2017 01:25 PM
Dear Canon,
Can we assume from your silence that you just want us all to buy Brother printers as many commenters have recommended? Why don't you just give us the answer here, so we can keep giving Canon money instead of switching over to customer service that actually cares about us customers and solving our frustrations?
Peace out.
08-09-2017 01:55 PM
Talked w Canon on the phone ... here are the steps they had me try:
NOTE: I'm having the same problem as everyone else ... printer makes printing sounds but doesn't print anything.
(1) try making a copy of something by putting a paper/photo on the glass screen and hitting "copy"
(2) if the paper is still blank, open up the print cartridge area and remove all ink cartridges. Lift up the gray bar. Remove the black base tray that holds the ink cartridges.
(3) Look at the gold connection squares on the bottom of the black tray. Do they look like they have ink smudges on them?
(4) Inside the printer in the space where the black tray connects up, look at the gold pins and see if they have ink on them or if any are bent or broken off.
(5) Insert the black tray back into the printer space. Lower the gray bar. Reinsert the ink cartridges. Make sure the red lights for each cartridge turn back on.
(6) Try making a copy of that paper/photo again.
(7) If it still doesn't print any ink and doesn't report any error messages, the problem is likely that the purge unit (the piece that sucks the ink out of the cartridges) or the print head are dead, but it's most likely the purge unit because no ink is shooting out.
(8) Canon offers info about print repairs for out-of-pocket costs.
(9) Canon offers to connect you with their upgrade department offer for replacement printer upgrade >>> 866-443-8002 >>> Here are the models they offer at a 25% discount for going through them:
* TS8020 (https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=ts8020&rh=i%3Aaps%2C...) or
* TS6020 (https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=ts6020&rh=i%3Aaps%2C...)
Now, dear Canon, why couldn't you type that out on here for us?
