01-20-2020 11:49 PM
I have a unit that I've reinstalled the driver on, have properly connected to the wireless LAN, have run the maintenance on, and can confirm that the device can print in black and white and can received print prompts from the computer.
After doing all the cleanings in setting, it prints some allignment page and the only one that shows up is the gridwork for PGBK. That's the only slot that has an active/full ink cartridge. I can also confirm through reinstalling the driver and printing a test page, it will print a sheet a paper with all that test page info on it.
I am trying to print a black and white outline (coloring page) and it will receive the "printing from PC" notice and start to "print". However, nothing comes out. Not if I print it from the image viewed, not from Print3D, not if I copy/paste it into Open Office Writer. I typed a test document and hit print and nothing. However, if I go into the Printer Properties and "print test page", works perfectly.
None of these are color prints, but I still have everything set to grayscale and monochrome. So the device can actually print, can receive a prompt from PC to print, but just not using PGBK only. All I ever want to do is print in black only.
Print processor: Canon MG5200 series print processor
OS en: Windows (10) x64
Driver Name: Canon MG5200 series Printer
Driver Type: Type 3 - User Mode
Driver Version: 2.56.2.10
"you have correctlyg installed you Canon MG5200 series Printer on DESKTOP-RKRTS3V"
Thanks.
01-21-2020 09:41 AM - edited 01-22-2020 09:43 AM
What is your paper type setting?
Anything but plain will use all colors to print "black"
