03-15-2019 12:47 PM
After aout a year of non-scanning I can't get it to scan, although it prints fine. I downloaded the latest drivers 5.1 but when I try install I get a pop up saying the MG 5220 can't be used for this download. Is there some place I can go to get the correct drivers for this model ???
03-27-2019 02:56 PM
Hello again,
You will need to have MP Navigator EX Ver. 4.03. Thet is the version for Windows 10 and the MG5220. Please remove both 5.0 and 5.1 and then click the link below, select the software tab and then download and install Ver. 4.03
03-29-2019 06:39 PM
03-18-2019 01:23 PM
Hi PeacockFeather,
So we can best assist you, please let us know what version of Windows or Macintosh is installed on your computer?
03-18-2019 03:29 PM
Windows 10
03-19-2019 03:02 PM
Hi PeacockFeather,
Please make sure you are downloading the driver from HERE and you are installing the MG5500 series MP Drivers Ver. 1.02.
Once the file is downloaded and the installer has been run, please open IJ Scan Utility again and try to scan. If there is any type of error (ex 2,157,50), I recommend contacting Windows to have them check your security software and firewall.
I have seen firewall and security programs block the scanning driver of the printer and produce this error. They can create an exception in the security to allow the driver and program to be used.
03-19-2019 11:20 PM
I ran this download from the pages you showed. Same problem. When I try to unload the driver I get a pop up that says:
Cannot load the MP Navigator EX.
The supported model of this software is as follows. Check to see if your product model is listed.
Then it gives a list. Nothing is listed for my product. So, now what???
03-20-2019 03:49 PM - last edited on 03-21-2019 05:18 PM by John_B
Hi PeacockFeather,
Sorry about that, I sent the wrong link. You will want to click HERE to open the support page for the MG5220. From here you can download the MG5200 series MP Driver Ver. 1.05.
Does the pop up saying the MG 5220 can't be used for this download appear again?
03-21-2019 05:14 PM
Yep. I downloaded the driver on the 2nd page you gave. I now have two navigator showing, 5.0 and 5.1. When I try to open, I Iget another pop-up with the same laguage , b ut a few of tlhe model numbers are differenmt, but no MG5220
03-27-2019 02:56 PM
Hello again,
03-29-2019 06:39 PM
Bingo! This worked for me .Thanks ArthurJ .
