MG3022 won't scan error message
amertat
I have re installed the software two times and still get the same error message.  What to do now?
"a required file is missing or corrupted, r settings are incorrect.  Try the installation again.  "
thank you,.
6 REPLIES 6
Moderator
Moderator
Hi, amertat!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
my operating system is mac os 10.14.2 mojove
help please someone
Hi, amertat,
The Canon Community Forum is not for immediate assistance. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE. You can also contact technical support at 1-800-OK-CANON (1-800-652-2666) Monday - Friday 8 am - 8 pm ET.
We hope this helps!
Hi amertat,
Did you install the ICA Driver Ver.4.3.4a or the full driver and software package? Also is the printer connected wirelessly or with a printer usb cord?
Thanks everyone.  I called canon and they gave me three files to download which I need to work with the updated version of OS (Mojave).  I guess every new version may require this or some of them.  But it works now at least with the mac softward, but if I try to use the cannon application it will not work.  But ok for now.  Solution found!
Holiday
