12-23-2022 07:31 PM
My printer is connected and works fine for documents; however when I print pictures there is an added white bar of 0.5 inches to one side of the pictures (sometimes at the bottom, sometimes to the left depending on orientation). How do you get pictures (i.e. a 4 x 6 to print out 4 x 6) without 0.5 inch of white added to the 4 x 6 picture?
12-23-2022 07:37 PM
If you want the image to completely cover the paper you need to select borderless printing.
You need to check your printer manual to see how to do it for your particular printer.
12-24-2022 08:30 AM
The only reference that I have run in to is "borderless printing is only available with paper rolls" - nothing more. I will have to download another manual as I seem to have misplaced the manual that came with the printer just to make sure on what I am remembering from reading online. I can't believe that a printer was designed like that. I have never even seen photo paper sold in rolls. There is a box to check for borderless printing but checking that does not make a difference.
12-24-2022 09:32 AM
INFORMATION FOUND IN ONLINE MANUAL: If printing on roll paper, you can set borderless printing in the printer driver settings. (If printing on sheets, borderless printing is not possible) Prints without Edges Based on the Scenarios (Windows) Prints without Edges Based on the Scenarios (macOS). My question now is what and where do I find "Scenarios"?
12-24-2022 10:03 AM
If the manual you are reading is talking about roll paper it is the wrong manual.
See here: Canon : Manuals : MG2520 : Select Device
