MG 2520 Won't feed paper
martygnt8
I have a MG 2520 and it will not feed paper.  It is communicating with computer and if I help push the paper through it will print.  When the rollers try to feed the bar bounces back and forth and knock really hard against the printer.  Sounds really loud.  Can anyone help, please.
3 REPLIES 3
Moderator
Moderator
Hi, martygnt8!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
Michael
Hello.
Unplug the power and remove any paper from the unit.  Next, make sure that there are no obstructions in the paper paths.  Once this has been done, turn the printer back on and load a single sheet of paper to see if the unit can print.
If the feedfing issues persist, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Drams
I have the same problem has anyone found a solution?
Holiday
