Ink Consumption TR150
rlsds
Does this printer consume ink upon being turned on? Some printers do that. If so, should i leave it turned on all the time? If i do that, will it not dry out the print heads? Which is best: leave it on or turn it off between jobs. We use it maybe three times a week.
Thanks
Patrick
Hi rlsds,
The TR150 will perform a cleaning when the printer is turned on, but it is not a "regular" cleaning.  It does this to ensure that the first print is accurate.  The amount of ink used in this process is very small.
If you are turning the printer on an off multiple times a day, you may see the ink levels drop.  If this is the case, I would recommend leaving the printer on until you are sure you are not going to print for an extended period of time.
1 REPLY 1
Patrick
Hi rlsds,
