I am trying to copy on a Canon MX922 and it is cutting off the the sides of the page and the bottom.
jeffparadise
I am trying to copy on a Canon MX922 and the sides and bottom is getting cut off. Is there a way to fix this? What settings do I need to change?
1 REPLY 1
Ramona
Hi jeffparadise,
You can try using the Fit-to-Page setting on the printer to see if this resolve the issue.  To do this, please follow these steps:
1.  Place the item you would like to copy on the platen glass of the printer, ensuring that the top of the original is lined up with the arrow that surrounds the platen glass.
2.  Press the COPY button.
3.  Press the right Function button below the LCD screen to display the Print Settings.
4.  Locate the Magnification section, then use the left/right arrow buttons to select the Fit to Page option, then press the OK button.  The printer will return to the main copy screen with Fit-to-Page selected.
5.  Press the Black or Color Start button to make a copy.
If you find that the Fit-to-Page option is not suitable, you can adjust the magnification up or down in 1% increments as well. To do this, please follow these steps:
4.  Locate the Magnification section, then press the right Function button below the LCD screen to display the Advanced settings.
5.  Use the up/down arrow buttons to adjust the magnification level in 1% increments, then press the OK button to save the change.  This will take you back to the Print Settings window, with the magnification selected showing.
6.  Press the OK button.  The printer will return to the main copy screen with Fit-to-Page selected.
7.  Press the Black or Color Start button to make a copy.
To return the printer to the default copy settings, please press the COPY button.
Hope this helps!
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
