How to wake up PIXMA TR7020a printer?
rtstover
Have TR7020a.  I never purposely turn the printer off because there are up to 3 users in the household who can use the printer at any time during the day.  If there is a 30-60 min. period of non-use the printer "goes to sleep" and in order to print you have to press the ON button.  I would like it to wake up when there a print job pending.  How do I make that happen?
ArthurJ
You can adjust the auto power settings in your TR7020 by using the steps HERE
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
5 REPLIES 5
ArthurJ
Thanks.  That did the job.
Arthur, unfortunately when I went back to re-read your excellent solution and selected HERE the system could no longer find the appropriate page.  Can you post the steps directly to your reply to this reply?
We apologize for any inconvenience, we've updated the link for you!
I have this same problem and these instructions do not seem to work.
My Auto Power Off is set to "Never" and Auto Power On is set to "On".
Everything was fine until recently the printer will only wake if I press a key on the printer's panel, for example "OK". So when using my iPad, for example, AirPrint cannot find any printers until I manually wake up the printer.
Note I have not made any printer setting changes, well, for years.
Any other suggestions?
Thank you!
Holiday
