How do i set up my PIXMA TR4720
Frankcolizzi
9 REPLIES 9
jrhoffman75
There should be a document in the box, usually a multi-color fold out poster, that guides you through it.
Moderator
Moderator
Thanks for joining the conversation, Frankcolizzi!  In addition to John's advice, you can also download everything you need to set up your PIXMA TR4720 for free right HERE.
Hope this helps!
2 weeks later and still not printing,  it does  photocopy
Register your product on the Canon site and contact Canon for support.
my screen   says that the app. that i am trying to install   is  not a  microsoft verified app.   ???????????
That's not good enough. He and I need help. I'll be calling Canon on Monday, but can you suggest anywhere else I can find help until then? (7/19/25)
@Frankcolizzi is probably using Windows 10 or Windows 11 S-mode.  This is the reason an operating system would say "it's not an approved Microsoft app".
@Niku,
To ensure your issue receives the visibility it deserves, please start your own topic to request assistance.  Your thread should include the model of your Canon product.  The operating system version and build you are using it with and how it is connected and to what?
Thanks in advance.  😉
https://community.usa.canon.com/t5/forums/postpage/choose-node/true/interaction-style/forum/override...
normadel
This is probably a dead issue for the original poster, but anyway......
Windows 11 has a function called "Driver Signature Enforcement".  Its purpose is to prevent installation of possibly-rogue drivers that can cause system damage. It can be temporarily disabled to allow installation of TRUSTED drivers that MS doesn't like. I've done this a number of times when I needed to add a driver in Win11 that had been fine in Win10 and earlier.
It involves starting up Windows in Recovery Mode and selecting "Disable Driver Signature Enforcement".  A web search for "disable Windows 11  Driver Signature Enforcement" will give the full procedure.
